Введение
Use this guide to replace the pitch bend rubber button of your OP-Z.
The actual button flex cable is a separate guide/part. Please disassemble and check your device before purchasing any parts.
Выберете то, что вам нужно
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
Use your finger or a spudger to push up on the small tab on the bottom of the module.
Lift the module up and out of its recess bottom first.
Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
Use a spudger or your finger to push the pitch bend button inwards.
