Введение
Use this guide to replace the volume potentiometer of your OP-Z.
In case the defect was caused by a drop then the volume knob was probably damaged too. This guide will also show how to replace the knob which can be purchased separately.
Выберете то, что вам нужно
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
Use your finger or a spudger to push up on the small tab on the bottom of the module.
Lift the module up and out of its recess bottom first.
Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
Use a spudger to disconnect the highway flex cable from the DSP board.
Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
Use one arm of a tweezer to lift the small black flap of the ZIF connector.
Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
