Tefal Actifry Disassembly
Выберете то, что вам нужно
  1. Tefal Actifry Disassembly, Tefal Actifry Disassembly: шаг 1, изображение 1 из 3 Tefal Actifry Disassembly, Tefal Actifry Disassembly: шаг 1, изображение 2 из 3 Tefal Actifry Disassembly, Tefal Actifry Disassembly: шаг 1, изображение 3 из 3
    • This is the Tefal Actifry as it would sit when being used. You will need to turn it upside down to see the three security screws that need to be removed. I have circled them in red here. The next photo shows a closeup of one of the screws.
  2. Tefal Actifry Disassembly: шаг 2, изображение 1 из 3 Tefal Actifry Disassembly: шаг 2, изображение 2 из 3 Tefal Actifry Disassembly: шаг 2, изображение 3 из 3
    • Next remove the three screws and the little fan cover at top end of the unit. I gently prised it off with a butter knife. This allows the bottom plastic cover of the Actifty to come off, from the fan end first, then it slips over the lid release buttons and off.
  3. Tefal Actifry Disassembly: шаг 3, изображение 1 из 3 Tefal Actifry Disassembly: шаг 3, изображение 2 из 3 Tefal Actifry Disassembly: шаг 3, изображение 3 из 3
    • The motor is now exposed with the bottom cover removed. There are two security screws, the same size as the ones on the outside cover that need removed. There are two wires that need removed from the old motor and inserted into the new motor. The new can be secured in place and tightened with the screws.
  4. Tefal Actifry Disassembly: шаг 4, изображение 1 из 2 Tefal Actifry Disassembly: шаг 4, изображение 2 из 2
    • When the wires are inserted snugly into the new motor and all is secure the bottom can be put back on the Actifry. Remember to slip it on in reverse of how you removed it. I had a little trouble getting it over the buttons, but it will with a little manipulation.
  5. Tefal Actifry Disassembly: шаг 5, изображение 1 из 2 Tefal Actifry Disassembly: шаг 5, изображение 2 из 2
    • I took my old motor apart to see why it wouldn't work. I discovered a circular magnet in the bottom, underneath the cogs etc. Upon closer inspection I seen it was cracked and a little pull and it came apart. It made it's way to the bin.
Заключение
34 участников успешно повторили данное руководство.
Declan Green
Участник с: 05/02/14
1 056 Репутация
1 руководство автора
35 Комментариев
Thank you for the great guide. I'd like to mention a few things I discovered disassembling my actifry while following your instructions:
* the screws on my unit were regular torx - ie not security torx which have the pin in the middle that require bits with a corresponding hollow hole.
* the fan cover is made of very brittle plastic and is easy to break when trying to pry off.
* the fan cover is held by 3 tabs at the 9, 3, and 12'o clock positions. It is easiest to pry from the the tabs at 9 and 3'o clock positions.
ifabri - Ответить
Thank you!! I am not at all DIY minded. I ordered a part for £12 on amazon, founder a screwdriver in my husband's toolbox, and fixed my actifry in under 5 minutes. Fab guide thank you!
Angharad - Ответить
Hi I've just fitted a new motor but now not getting hot. Do you think I need to replace element too? Also my friend has an actifry with same problem but can't find a motor for the model AL806240. Any ideas where she can get one. The wires seem to sit differently than mine. Thank you
Jean Hennedy - Ответить
This is what is happening to mine. I have replaced the motor and now the actifry is not heating… did you find the solution? Thanks
l.z.macintyre -
Thanks, saved time figuring out exactly how to do it - though you need a couple of more pictures in the guide. I had to deform the case a bit in order to clear over the fan otherwise it cannot slip over the fan - people be careful not to stress the fan assembly: you should slide the case without touching the fan.
In my case, the security screws *just* got unscrewed by a not-security screwdriver bit so I just replaced them with normal philips ones on reassembly.
MiKa - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 32
За последние 7 дней: 145
За последние 30 дней: 638
За всё время: 115,172
