Введение
I've repaired this problem several times using this method and it works well.
Выберете то, что вам нужно
Kids pulled the cable connector off the back of the hello kitty TV
Remove screws from back, there's 5 in this case circled in red.
Notice the parts container highlighted in orange always a good idea for screws.
Cookie circled in pink for good measure.
High voltage areas are outlined in red.
Delicate sensitive areas outlined in blue.
remove both covers on video input box, use a small prying tool if necessary, but you should be able to remove them by hand as seen here.
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Use a soldering iron, and solder sucker to remove excess solder from the connector area. You can also use solder-absorbing braided wick.
identify, where the centre pin connector was ripped from the board.
Use needle-nose pliers to straighten out the tin bracket as much as possible. It does not need to be perfect, but this helps with the alignment of the connector to the back of the tv cover.
Align the connector, ensuring the center pin can reach the the spot on the board where it needs to be re-connected.
Solder the barrel of the connector to the metal bracket first, try not to let it get too hot. You may want to use a solder gun with dual heat of at least 50 watts for this part.
When that's done don't forget to solder the center pin to the board using as little solder as possible, to ensure there's no grounding to the metal cover.
Carefully replace the plastic cover. Replace cover screws.
No Phosphorus (P). The phosphors contain Cadmium (Cd). The CRT glass is made with Barium (Ba) and Lead (Pb). Vacuum is not inherently a danger. Implosion is very unlikely. I have broken many a CRT and it takes quite an effort unless you smack it on the relatively fragile neck. No dramatic explosion. No shards of flying glass. Just a crack and a whistle and cursing.
8 участников успешно повторили данное руководство.
6 Комментариев
cara memperbaiki warna
where can i get the connectors?
C'est très intéressant, Mais seulement si vous pouvez traduire en français
11.11.16 Francais en anglaise= French to english. It's very interesting. I only wish u'd translate into French!
Hi. Finding this post ten years after the fact. My problem is that a coax cable pin connector accidentally broke off inside the coax port. Wondering if it's possible to push the broken piece back out of the port from the inside, if there's access to the port's hole from the inside of the chassis? Thanks much. Be blessed today!
