Введение
For this repair you will be removing your old grip and replacing it with a new Replacement Grip that you purchased from a sports store. This guide will also explain how to apply an Overgrip that you may have purchased for a variety of reasons: disliking the texture of the replacement grip, feeling you want a thicker grip, or simply wish to protect the more expensive Replacement Grip.
Выберете то, что вам нужно
Pull the rubber collar towards the tennis racquet head off the handle.
Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
If you are right-handed, wrap the tape towards the left
Wrap the grip flush with the buttcap base.
Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
Wrap the handle top with the backing on.
Mark a horizontal line parallel to the buttcap around the grip.
Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
Pull the collar up off the handle.
Repeat steps 4 - 11 to apply the overgrip.
I wrote a bout this but you just hit the nail! Thanks for sharing … The Best Way to Regrip a Tennis Racquet
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
6 участников успешно повторили данное руководство.
4 Комментариев
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
I use this tennis guide, it’s quite worthy.
