Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Pull the rubber collar towards the tennis racquet head off the handle.
Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
If you are right-handed, wrap the tape towards the left
Wrap the grip flush with the buttcap base.
Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
Wrap the handle top with the backing on.
Mark a horizontal line parallel to the buttcap around the grip.
Cut along the marked line using either scissors or a knife.
Remove the backing and finish wrapping the replacement grip.
Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
Complete your fix by pulling the rubber collar back to its original location.
Pull the collar up off the handle.
Repeat steps 4 - 11 to apply the overgrip.
6 участников успешно повторили данное руководство.
4 Комментариев
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
I use this tennis guide, it’s quite worthy.
