Введение
This guide will illustrate how to replace the shock cord in tent poles with a bobby pin and string. There are many other methods that can be used to feed the shock cord through tent poles, but when away from home, a bobby pin and string can save the day.
Выберете то, что вам нужно
Tie the string around the end of the bobby pin.
The string and bobby pin will be used to feed the shock cord through the pole.
Drop the bobby pin and string through the tent pole pieces one by one.
Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
Once the last piece has been threaded, untie or cut the string from the shock cord.
Tie a large knot against the right end of the last piece.
Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
Tie a large knot around the tent pole end piece.
Fit the end piece into the left end of the first pole.
3 участников успешно повторили данное руководство.
