Выберете то, что вам нужно
Lever up the battery cover by using a small screwdriver or similar device.
Using the same lever device used to remove the cover, lever out the battery where indicated.
Remove the battery
Replace the battery with your replacement CR2032 in the same manner as it was removed.
And that’s it! Go for a drive!
Еще один человек закончил это руководство.
