Введение
The boiler heat the water to the needed temperature for both the steam wand and portafilter. If your machine isn't heating up, one possible cause is a failed heating element inside the boiler. This guide will show you how to test for this.
Выберете то, что вам нужно
Remove the 6 Phillips #1 screws from the back panel.
Remove the back panel.
Make sure the machine is turned off and unplugged.
Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
If given a reading, then your heating element is fine.
In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
Place a cup, to catch fluid, underneath the portafilter.
Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
See the links section of the device page for further directions.
11 участников успешно повторили данное руководство.
6 Комментариев
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
I feel the temperature of the espressos i’m making is not hot enough. How do i raise the thermostat to activate the Ready light at a higher temp?
