Texas Instruments TI-30X IIS Battery Replacement
Выберете то, что вам нужно
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: шаг 1, изображение 1 из 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: шаг 1, изображение 2 из 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: шаг 1, изображение 3 из 3
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: шаг 2, изображение 1 из 2 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: шаг 2, изображение 2 из 2
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: шаг 3, изображение 1 из 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: шаг 3, изображение 2 из 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: шаг 3, изображение 3 из 3
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: шаг 4, изображение 1 из 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: шаг 4, изображение 2 из 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: шаг 4, изображение 3 из 3
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: шаг 5, изображение 1 из 1
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
Заключение
20 человек успешно провели ремонт по этому руководству.
Ryan
Участник с: 03/01/15
515 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 49
За последние 30 дней: 175
За всё время: 34,856
