Texas Instruments TI-30Xa Battery Replacement
Выберете то, что вам нужно
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: шаг 1, изображение 1 из 1
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: шаг 2, изображение 1 из 2 Texas Instruments TI-30Xa Battery Replacement: шаг 2, изображение 2 из 2
    • Locate the six screws on the back of the calculator.
    • With a Phillips #0 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: шаг 3, изображение 1 из 3 Texas Instruments TI-30Xa Battery Replacement: шаг 3, изображение 2 из 3 Texas Instruments TI-30Xa Battery Replacement: шаг 3, изображение 3 из 3
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: шаг 4, изображение 1 из 1
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: шаг 5, изображение 1 из 2 Texas Instruments TI-30Xa Battery Replacement: шаг 5, изображение 2 из 2
    • The two LR44 batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
Заключение
54 участников успешно повторили данное руководство.
Chris L
Участник с: 12/17/14
1 498 Репутация
Автор 3 руководств
30 Комментариев
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
Scott Julien - Ответить
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Dewellah - Ответить
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
lasharlavenue - Ответить
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
Esther Reese - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 31
За последние 7 дней: 166
За последние 30 дней: 811
За всё время: 113,532
