Введение
Power cords can become damaged due to pinching or cutting of the cord. Follow this guide to replace the power cord.
Выберете то, что вам нужно
Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
Remove the top cover.
Gently pull up on the power cord to remove it from the back cover.
Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
Gently remove the transformer.
Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
Twist the exposed section of the 2 wires together.
Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
Repeat steps 4-6 for the second set of wires.
Replace the transformer and ensure that the new wire caps fit in the space shown.
Plug in the new power cord and test the calculator before replacing the top cover.
Еще один человек закончил это руководство.
