Введение
Follow this guide to remove and replace the printing unit in the TI-5130 electronic calculator.
Выберете то, что вам нужно
Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
Remove the printer unit by lifting it up.
3 участников успешно повторили данное руководство.
2 Комментариев
wehre did you buy the replacement printer
what sources are there for TI-5130 printer unit?
