Введение
If you are experiencing trouble with the claw or it does not seem to be opening or closing properly, it is possible that the claw itself is broken or damaged. This requires the user to open the claw device in order to access the mechanical claw. Follow this easy guide in order to properly and easily replace your claw.
Выберете то, что вам нужно
Place The Claw machine in the up-right position with the control knobs facing you.
Turn The Claw machine upside-down placing the top cover on the surface of your work area.
Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
2 участников успешно повторили данное руководство.
6 Комментариев
Where do I buy a new grabber thing
The 1st joystick that moves the claw forward and back doesn’t work.
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
My chain fell off and I dont know how to fix
