Введение
If the clear plastic case on your claw device is broken or damaged, it can easily be replaced. This required the opening of the top cover of your claw device in order to access the clear plastic panels. Using this easy to follow replacement guide will make case replacement an easy task.
Выберете то, что вам нужно
Place The Claw machine in the up-right position with the control knobs facing you.
Turn The Claw machine upside-down placing the top cover on the surface of your work area.
Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
2 участников успешно повторили данное руководство.
