Themotop Combination Central Heating and Boiler Micro Switch Maintainence
  1. Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 1, изображение 1 из 3 Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 1, изображение 2 из 3 Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 1, изображение 3 из 3
    • PROBLEM: faulty micro switch. FIX: Disconnect power mains!!! remove the switch, check the conductivity with a multimeter.
  2. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 2, изображение 1 из 3 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 2, изображение 2 из 3 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 2, изображение 3 из 3
    • FIX: Disconnect power mains!!! remove the switch, check the conductivity with a multimeter. if the switch is faulty remove the green seal and drip some contact cleaner (alcohol) into the switch. Check the conductivity again. Let it dry upside down in a hot dry place.
  3. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 3, изображение 1 из 2 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 3, изображение 2 из 2
    • check the conductivity with a multimeter. if the switch is faulty remove the green seal and drip some alcohol into the switch. Check the conductivity again. Let it dry upside down in a hot dry place. Buy a new one if it's still bad.
  4. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: шаг 4, изображение 1 из 1
    • Put it back, reconnect mains but keep an eye on the gas flame that might turn on without the switch is being pressed (if it is so the switch is not dry inside). Say thanks to me ( atosmaximus (at) gmail.com :-)
Заключение
5 участников успешно повторили данное руководство.
atos maximus
Участник с: 10/06/13
510 Репутация
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 3,383
