ThinkPad X1 Carbon Fan Replacement
Выберете то, что вам нужно
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: шаг 1, изображение 1 из 1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: шаг 2, изображение 1 из 1
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: шаг 3, изображение 1 из 1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: шаг 5, изображение 1 из 1
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: шаг 6, изображение 1 из 1
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
Заключение
9 участников успешно повторили данное руководство.
Mike
Участник с: 06/23/16
1 834 Репутация
Автор 5 руководств
Команда
iReconstruction Участник iReconstruction
Business
1 член
Автор 11 руководств
Один комментарий
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 26
За последние 30 дней: 116
За всё время: 12,649
