Введение
Now your computer battery power will finally last over 1 hour!
  1. Remove the nine Phillips screws using a Philips 00 screwdriver
    • Remove the nine Phillips screws using a Philips 00 screwdriver
  2. Pry up the case carefully using a spudger.
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
    • Lift off the cover, and you're done!
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
    • Carefully pull the connector out from underneath the logic board to remove the battery.
Заключение
3 участников успешно повторили данное руководство.
Tanner Lange
Участник с: 18.03.2018
909 Репутация
Автор 3 руководств
Команда
Francophones Member of Francophones
Community
9 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 3
За 7 дней: 35
За 30 дней: 121
За всё время: 803
