Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement
Выберете то, что вам нужно
  1. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: шаг 1, изображение 1 из 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: шаг 1, изображение 2 из 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: шаг 1, изображение 3 из 3
    • Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 2, изображение 1 из 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 2, изображение 2 из 3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 2, изображение 3 из 3
    • Remove the 10mm long black screws on the back of the base using a PH2 Phillips head screw driver. There are 13 screws total.
    • Gently lift cover out to access inside.
    • There is a screw behind the cable.
    • In the picture you see a plastic opining tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  3. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 3, изображение 1 из 2 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 3, изображение 2 из 2
    • Push the pin that holds the pedal out from middle outward.
    • There are two springs that hold the pedal upward. Make sure the pin goes through the springs and the pedal when installing new pedal.
  4. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: шаг 4, изображение 1 из 1
    • Install the new pedal with springs and pin and make sure that the pin holds them together.
    • Add a little grease on pin when installing the new pedal.
    • Repeat steps in reverse to reassemble device.
    • Wash your hands after you finish dealing with grease. it is a dangerous material will cause problems if it gets in your eyes or get swallowed.
Заключение
2 участников успешно повторили данное руководство.
Mario Nunez
Участник с: 10/18/17
421 Репутация
Автор 3 руководств
Команда
USF Tampa, Team S1-G33, Cagle Fall 2017 Участник USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 членов
Автор 5 руководств
6 Комментариев
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
Alex Ruiz - Ответить
I am also looking for this spring. Any help would be appreciated.
thanks
Maxime Viens -
Me too. Are these springs available?
Jay Nicholson - Ответить
I only need 1 spring, not 10....
Anyone selling 1 spring?
fnaf master101 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 17
За последние 30 дней: 85
За всё время: 11,601
