Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement
Выберете то, что вам нужно
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: шаг 2, изображение 1 из 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: шаг 2, изображение 2 из 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: шаг 3, изображение 1 из 2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: шаг 3, изображение 2 из 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
Заключение
2 участников успешно повторили данное руководство.
Mario Nunez
Участник с: 10/18/17
421 Репутация
Автор 3 руководств
Команда
USF Tampa, Team S1-G33, Cagle Fall 2017 Участник USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 членов
Автор 5 руководств
2 Комментариев
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - Ответить
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 40
За всё время: 5,465
