Введение
This guide will show you how to replace the connection port for the pedals.
Выберете то, что вам нужно
Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
Gently pull apart both halves of device to access inside.
Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
By pulling up on both ends of the port you will be able to pull out the port to remove it.
2 участников успешно повторили данное руководство.
2 Комментариев
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
