Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
Выберете то, что вам нужно
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: шаг 1, изображение 1 из 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: шаг 2, изображение 1 из 2 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: шаг 2, изображение 2 из 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
Заключение
Еще один человек закончил это руководство.
Mohammed Alsogair
Участник с: 10/18/17
339 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S1-G33, Cagle Fall 2017 Участник USF Tampa, Team S1-G33, Cagle Fall 2017
USFT-CAGLE-F17S1G33
4 членов
Автор 5 руководств
3 Комментариев
how can I replace elastic cord?
geoff - Ответить
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - Ответить
Where did you get a replacement motherboard?
Paul Stewart - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 122
За всё время: 5,319
