Введение
The Motherboard contains all the 'brains' of the device. In case this component needs to be replaced, this guide will walk you through the installation of the motherboard.
Запчасти
Никакие детали не требуются.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Unplug the fan from the motherboard by gently pulling up on the red plug.
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  7. Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  8. Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  9. Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  10. Locate the four metal tabs on the motherboard. Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  11. Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  12. Pull directly up on the motherboard so that it slips over the four golden metal tabs. Pull up and away from the back panel so all of the cable inputs slip through the casing.
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
Заключение
Cody Hunter
Участник с: 10.10.2011
22 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 5-33, Amido Fall 2011 Member of Cal Poly, Team 5-33, Amido Fall 2011
CPSU-AMIDO-F11S5G33
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 4
За всё время: 981
