Введение
In case your remote just won't work and you have already tried replacing the batteries, this guide will walk you through removing the front cover and replacing the remote sensor on the inside of the cover.
Выберете то, что вам нужно
Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
