Выберете то, что вам нужно
Power down the TiVo and detach the power cable from the rear of the unit.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
Remove the four plastic standoffs.
Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
2 участников успешно повторили данное руководство.
