Введение
This guide is for if you conclude that your difficulty with braking is due to your brake cables being too loose.
Запчасти
Никакие детали не требуются.
  1. Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
    • Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
  2. Pull the brake cable until proper tension is acquired and the cable shows resistance.
    • Pull the brake cable until proper tension is acquired and the cable shows resistance.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Re-tighten the clamping nut.
    • Re-tighten the clamping nut.
  5. If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
    • If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
  6. For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
    • For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
Заключение
Your brakes should be fully tightened now.
8 участников успешно повторили данное руководство.
Samantha Rawlins
Участник с: 21.01.2014
425 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 1-40, Maness Winter 2014 Member of Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 членов
Автор 5 руководств
Один комментарий
Thank God I didn’t have to watch someone's long winded 10 minute video explaining this.  lol Thank you for that!  Great article.  Thanks for helping me out!
rtinmotion - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 6
За всё время: 1,848
