Введение
This guide is for if you conclude that your difficulty with braking is due to your brake cables being too loose.
Запчасти
No parts specified.
  1. Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
    • Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
  2. Pull the brake cable until proper tension is acquired and the cable shows resistance.
    • Pull the brake cable until proper tension is acquired and the cable shows resistance.
  3. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  4. Re-tighten the clamping nut.
    • Re-tighten the clamping nut.
  5. If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
    • If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
  6. For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
    • For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
Итог
Your brakes should be fully tightened now.
8 участников успешно повторили данное руководство.
Samantha Rawlins
Участник с: 21.01.2014
425 Reputation
Автор 3 руководств
Cal Poly, Team 1-40, Maness Winter 2014 Member of Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 членов
Автор 5 руководств
One Comment
Thank God I didn’t have to watch someone's long winded 10 minute video explaining this.  lol Thank you for that!  Great article.  Thanks for helping me out!
rtinmotion - Ответить
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,054
