Timex T132 "iMac" Alarm Clock Battery Replacement
Выберете то, что вам нужно
  1. Timex T132 "iMac" Alarm Clock Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • To prevent any injury, unplug the power cord from the outlet so the device is powered off.
    • Hold the clock so it is upside down. You should be able to view its caution labels.
    • Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
    • Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
  2. Timex T132 "iMac" Alarm Clock Battery Replacement: шаг 2, изображение 1 из 3 Timex T132 "iMac" Alarm Clock Battery Replacement: шаг 2, изображение 2 из 3 Timex T132 "iMac" Alarm Clock Battery Replacement: шаг 2, изображение 3 из 3
    • Rotate the device so the clock's display is facing away from you.
    • Use the flat end of the spudger to pry out the battery.
    • Once fully lifted, grab the end of the battery and pull out the rest of the battery.
    • Do not remove the battery all the way because it is still connected. Doing so may result in damaging the power wires.
  3. Timex T132 "iMac" Alarm Clock Battery Replacement: шаг 3, изображение 1 из 1
    • Place the clock upside down on a flat surface.
    • Because the device is irregularly shaped, you may have to manually or externally balance it.
    • Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
    • Do not pull out the snap connector and its wires because it is still connected to the device. Doing so may result in damaging the power wires.
    • Remove the battery.
Заключение
Tyler Price
Участник с: 04/07/14
1 038 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 6-2, Forte Spring 2014 Участник Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 302
