Введение
Use this guide to replace the dead battery on your Timex T132 "iMac" alarm clock.
Выберете то, что вам нужно
Hold the clock so it is upside down. You should be able to view its caution labels.
Wedge the small tip plastic opening tool between the battery cover and the edge of its slot.
Firmly push against the battery cover (away from its outer edge) until it slides off of the base clock.
Rotate the device so the clock's display is facing away from you.
Use the flat end of the spudger to pry out the battery.
Once fully lifted, grab the end of the battery and pull out the rest of the battery.
Place the clock upside down on a flat surface.
Grab the blue connector covering tab near the power wires and peel the snap connector off the battery terminals to disconnect it.
Remove the battery.
