Tips on How to micro Solder on a budget
Выберете то, что вам нужно
  1. Tips on How to micro Solder on a budget, Remove defective part: шаг 1, изображение 1 из 1
    • Problem was broken power connecter on grandsons Kindle. Removed bad connector and broken trace came up with part. New connector also shown.
    • I used a soldering iron with a 700 degree tip and de-solder braid to remove defective part. Hot air gun would have been a better option but I didn't have one.
    • Enlarge the image to zoom in and see fine detail. Also how I checked the work.
  2. Tips on How to micro Solder on a budget, Prep for repair: шаг 2, изображение 1 из 1
    • After cleaning up the board and reseating new socket I simply resoldered in place. Now with the new socket installed, I needed to connect the unsoldered lead to the data port on board.
    • To find where the trace/lead went to I went to the Internet to find where it connected. I found many usable images to determine the path.
    • To remove the coating on the board where I needed to solder , I scrapped away the coating with an Xacto knife.
  3. Tips on How to micro Solder on a budget, Prep to solder: шаг 3, изображение 1 из 1
    • Stripping and tinning a piece of 60mm wire I layed it in the path where I needed to attach. I bent the wire to give better leverage.
  4. Tips on How to micro Solder on a budget, Secure wire for soldering: шаг 4, изображение 1 из 1
    • Putting a piece of electrical tape over a bent wire kept it in place
  5. Tips on How to micro Solder on a budget, Trim to fit: шаг 5, изображение 1 из 1
    • Using a fine tip on my iron , I again used a 700 degree tip , dabbed the area with liquid flux and soldered the wire to the lead and exposed trace.
    • When done I removed tape, cleaned flux off and trimmed wire to length.
    • You must have a steady grip on your iron to attach the wire. By using a long wire, you make it easier to keep it in place as you solder and it's so thin you can remove the excess wire with little stress to the repair.
  6. Tips on How to micro Solder on a budget, Size reference: шаг 6, изображение 1 из 1
    • The repair was the size of the wire next to the finger posted here
  7. Tips on How to micro Solder on a budget, Seeing up close: шаг 7, изображение 1 из 1
    • Not very high tech, but it got me through this without a proper scope. In this image I was verifying I didn't have any solder bridges on socket.
    • When everything was cleaned back up I put the Kindle back together and it charges and plays like it should.
    • When I was done soldering I used my iPad Pro 9.7 to take hi resolution image that I could view and blowup to ensure the repair was intact and clean
Заключение
using this technique, you can get yourself out of a pinch by repairing an item half the length of rice ,and half as thick.
63 участников успешно повторили данное руководство.
Ken
Участник с: 01/29/10
12 023 Репутация
1 руководство автора
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 528 руководств
5 Комментариев
I am a tinkerer lol and am getting into building racing drones. could you pls tell me where a good learning guide is for micro sodering?? I've been practicing on old boards and whatnot but when I try soldering a wire to the board the solder wants to ball up or not attach the wire. also is cleaning the board important? pls help its so frustrating!! lol and any general tips or tricks for soldering would be GREATLY appreciated friend
dustykeith17 - Ответить
Cleaning after soldering really depends on the type of flux you use. Some are cleaner than others. Use an inexpensive microscope. Look at these skills tutorials: Soldering Skills. Be patient and enjoy.
Ken - Ответить
If the old solder is relatively clean and there’s no excess, would de soldering still be “necessary” to make proper connection? Or could you just melt a little more solder on them til enough of a ball is present to reattach the part and have solid connection? (Part in question is a fan socket for a mid 2012 13” MacBook Pro)
matthew storstad - Ответить
it’s easier for me to attempt micro/soldering rather than pay $100+ for a new board. It’s dead already, right ?
I’d like advise in a few areas. First, equipment. I need some decent helping hands and vise to keep the items steady. A pen style iron and station. Second, when is a desoldering gun appropriate ? Third and most importantly, I need to know how to solder a post that has broken flush with the pcb board.
James Walker - Ответить
you can make an excellent digital magnifyer by using your smartphone. Pick up an adjustable phone stand from Ocean State Job Lot for 5 bucks. Put your phone on it and go to your camera mode. You can use the zoom to see the circuits you are working on up close and crystal clear.
carl hungus - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 64
За последние 30 дней: 261
За всё время: 32,278
