Введение
Use this guide to replace and discharge the set of capacitors in your Titan Impact 410 Airless Sprayer.
Note: To ensure the capacitors are fully discharged, unplug the sprayer for at least 20 minutes before beginning any repairs.
Выберете то, что вам нужно
Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
Disconnect the black negative wire's spade connector.
Disconnect the red positive wire's bullet connector.
Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
Pry up to separate the bottom cell from the motor body.
Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
Pry up to separate the rest of the capacitor from the motor body.
Remove the capacitor.
Еще один человек закончил это руководство.
