Введение
Use this guide to replace the seal assembly on your RX-80 spray gun.
For more safety information, refer to the Operating Manual.
Выберете то, что вам нужно
Pull the diffuser straight off the seal assembly to remove it.
Use an adjustable wrench to loosen the rear housing on the back of the spray gun.
Pull the rear housing straight off the spray gun to remove it.
Use a 3/8 inch socket to loosen the lock nut from the back of the spray gun.
Pull the lock nut straight off the spray gun to remove it.
Use your fingers or a pick tool to remove the retractor plate and its two alignment pins from the spray gun.
Pull the seal assembly through the front of the spray gun to remove it.
Еще один человек закончил это руководство.
