Введение
This guide is for replacing the daughter board of the Tivax STB-T9 Digital TV Converter Box. The daughter board receives signals from the TV remote and sends them to the main circuit board to be processed and control the TV. The daughter board also takes in signals from buttons on the front of the converter (Power Button and Channel Up/Down). Without the daughter board the converter will not work, so it is an essential part.
Выберете то, что вам нужно
Remove the four screws holding the box together. 1 on each side and 2 on the back.
Turn the converter upside down.
Remove the two screws connecting the face plate the the main box.
Once screws are removed, take off case by first pulling up on the back and then sliding away from the front.
Locate the white connector attached to the faceplate by black wires.
Place your forefinger and thumb on the sides of the connector. With little force, you should be able to pull the connector out.
Locate the daughter board in the face plate.
Remove the four screws connecting the daughter board to the face plate.
To reassemble your device please follow the steps in reverse order.
