Введение
The blades on the Nose & Ear trimmer eventually wear out and require replacement. The following steps will guide you through how to safely and successfully replace these blades.
Выберете то, что вам нужно
Twist the battery cap found on the bottom of the device counterclockwise.
Twist the tip of the trimmer counterclockwise to remove it.
The trimmer blade assembly will be located on the inside of the tip.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using the tweezers, pull the blade assembly out of the trimmer tip.
Заключение
