Toilet Water Supply Line Replacement
Выберете то, что вам нужно
  1. Toilet Water Supply Line Replacement, Water Supply Line: шаг 1, изображение 1 из 3 Toilet Water Supply Line Replacement, Water Supply Line: шаг 1, изображение 2 из 3 Toilet Water Supply Line Replacement, Water Supply Line: шаг 1, изображение 3 из 3
    • Before any work is done, inspect the hardware carefully and note any concerns. Locate the shut off valve underneath the toilet and turn it clockwise until it cannot turn any further. Do not turn past the stop point as this could damage the hardware completely.
    • The valves differ from toilet to toilet but the majority operate the same.
    • If water is active in the line when the turn action is complete the, a complete shut off of water from the main value of the home might be necessary.
  2. Toilet Water Supply Line Replacement: шаг 3, изображение 1 из 2 Toilet Water Supply Line Replacement: шаг 3, изображение 2 из 2
    • Next, hold down the flush lever/button until all the water in the tank is drained from the tank.
    • A little water may still remain in the tank. You will need to remove this water as well.
  3. Toilet Water Supply Line Replacement: шаг 4, изображение 1 из 1
    • To remove any excess water from the tank. Place a container to catch the water that might drain by placing a bucket with a towel underneath the toilet to catch any water.
  4. Toilet Water Supply Line Replacement: шаг 5, изображение 1 из 3 Toilet Water Supply Line Replacement: шаг 5, изображение 2 из 3 Toilet Water Supply Line Replacement: шаг 5, изображение 3 из 3
    • Use a vice grip to loosen the nut attached to the main waterline.
    • Use your hand to loosen the Bullock Nut attached to the toilet tank.
    • Get the bucket ready to catch any excess water from the toilet tank.
  5. Toilet Water Supply Line Replacement: шаг 6, изображение 1 из 2 Toilet Water Supply Line Replacement: шаг 6, изображение 2 из 2
    • Attach the nut of the new flex water supply line to the main water line.
    • Using your vice grips, tighten the nut counter-clockwise.
  6. Toilet Water Supply Line Replacement: шаг 7, изображение 1 из 2 Toilet Water Supply Line Replacement: шаг 7, изображение 2 из 2
    • Attach the Bullock Nut to the threads on the bottom of the toilet tank and hand tighten the nut counter-clockwise.
  7. Toilet Water Supply Line Replacement: шаг 8, изображение 1 из 2 Toilet Water Supply Line Replacement: шаг 8, изображение 2 из 2
    • Turn the knob attached to the main water line on, counter-clockwise.
    • Once the water is restored be sure to check for any leaks.
Заключение
Еще один человек закончил это руководство.
Nicholas Mills
Участник с: 09/16/20
166 Репутация
1 руководство автора
Команда
York University, Team S3-G58, Melo-Thaiss Fall 2020 Участник York University, Team S3-G58, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G58
1 член
Автор 1 руководств
Один комментарий
I have a rigid supply line and afraid of damaging faucet because when I use an open end wrench it shakesi used steel wool on supply line to clean up - I used a metal brush on top of nut to clean it up I sprayed lubricating oil on suppply line going into nut and top of nut. Any suggestions?
John Mack - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 59
За последние 30 дней: 270
За всё время: 6,539
