Введение
Is your device getting too hot? The following steps indicate how to remove and replace the motor. For this repair you will need a black spudger, an allen wrench attachment, and a phillips #00 screwdriver.
Выберете то, что вам нужно
Using the black spudger, remove the two rubber covers to reveal the screws underneath.
Take off the cap of the massage gun, watch out the back part of the gun with the integrated circuit might fall off so make sure you secure it while taking off the cap.
Remove the two 8.24 mm silver screws on the top of the lever arm with the Phillips #00 screwdriver.
Remove the 14.85 mm black screw from the underside of the rotary arm with allen wrench attachment.
Remove the four 11.26 mm silver screws from each side of the motor frame with a Phillips #00 screwdriver.
Remove the two 6.14 mm silver screws located on the top plate with a Phillips #00 screwdriver.
Grasp the plate and carefully pull up to remove the plate from the device.
