Введение
Is your device making excessive noise? The following are the steps to take to replace the two small washers connected to the lever arm. Broken or malfunctioning washers can cause noises and a less smooth massage. Thus, if the massage gun makes noises it is not supposed to make, a replacement of said washers might be a solution.
Выберете то, что вам нужно
Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
