Введение
If the device's screen is experiencing problems in its visuals, such as discoloration or image distortion, your device may need a display replacement. Otherwise, if the device does not register touches then you may want to replace the digitizer. Confirm the device is powered off before starting the disassembly.
Выберете то, что вам нужно
Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
With the screen casing unlatched, locate the right side where the two connectors are.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the microphone on the left side of the screen casing using tweezers.
Lift up the small black tab on the orange connector using a plastic opening tool. This releases the strip connecting the display to the digitizer.
Unscrew the eight 2.5mm screws along the perimeter of the display using the Phillips #000 screwdriver.
Separate the display from the digitizer. The display is now fully removed from the device.
6 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
If you keep the bezel and replace the glass, ensure the glass has adhesive before you buy.
Do you have branch in Istanbul?
if yes please provide me the address. thaxs
pertituire schermo e display cosa devo fare e comprare grazie
