Введение
If your TomTom Go Live does not seem to be charging or hold said charge, then the battery needs to be replaced. This guide will show how to take this device apart and replace the battery without damaging the screen or cables.
Выберете то, что вам нужно
Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
Carefully remove the reset button cable (located on the left) and the ribbon cable.
Remove the screen and set it aside.
Remove the 3.6mm screws with a Phillips Screwdriver.
After removing the screws simply lift the logic board from the base.
Simply lift the battery up and out of the base.
Remove the cable.
Replace the battery.
4 участников успешно повторили данное руководство.
