Введение
Please check out the TomTom GO Live 1535M Troubleshooting Guide before taking the device apart to ensure you are following the correct repair procedure.
Запчасти
Никакие детали не требуются.
  1. Slip a small  opening tool underneath the screen, gently sliding it around the outside edge.
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • To do this, it may be easier to start at the corners.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Carefully remove the reset button cable (located on the left) and the ribbon cable. Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
  4. The screen is simply removed by pushing it up-and-out of the outside rim (denoted by the box). As you remove the screen, you may hear a 'tearing' sound. Do not panic, as this is just the leftover substance that holds the screen in place. It will re-stick when the screen in placed back. If you need to find a replacement screen, please click the link here.  Link text
    • The screen is simply removed by pushing it up-and-out of the outside rim (denoted by the box).
    • As you remove the screen, you may hear a 'tearing' sound. Do not panic, as this is just the leftover substance that holds the screen in place. It will re-stick when the screen in placed back.
    • If you need to find a replacement screen, please click the link here. Link text
Заключение
2 участников успешно повторили данное руководство.
Mathias Sagide
Участник с: 20.01.2015
603 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 19-4, Blackwell Spring 2014 Member of USF Tampa, Team 19-4, Blackwell Spring 2014
USFT-BLACKWELL-S14S19G4
1 член
Автор 5 руководств
Один комментарий
I just replaced the screen. But with the cable ribbon installed the screen does not activate. The startup tom-tom sound does play. The screen is blank. But the old screen does not work as well. Prior to this the screen did work but was un responsive. Any thoughts?
Steven Kawchak - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 8
За всё время: 653
