Введение
Overtime the motherboard's wires may come apart and make the device stop working. This guide will show you how to replace the motherboard with a new one.
Выберете то, что вам нужно
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
Next, you must remove the motherboard from the front screen.
Use a Torx T-7 screwdriver to unscrew the two screws.
Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
4 участников успешно повторили данное руководство.
