TomTom ONE Screen Replacement
Выберете то, что вам нужно
  1. TomTom ONE Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: шаг 2, изображение 1 из 2 TomTom ONE Screen Replacement: шаг 2, изображение 2 из 2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: шаг 3, изображение 1 из 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: шаг 4, изображение 1 из 1
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: шаг 5, изображение 1 из 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: шаг 6, изображение 1 из 2 TomTom ONE Screen Replacement: шаг 6, изображение 2 из 2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: шаг 7, изображение 1 из 1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: шаг 8, изображение 1 из 2 TomTom ONE Screen Replacement: шаг 8, изображение 2 из 2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
Финишная черта
2 участников успешно повторили данное руководство.
Alex Cauvy
Участник с: 04/18/10
41 Репутация
1 руководство автора
Команда
Cal Poly, Team 7-7, Maness Spring 2010 Участник Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 9,800
