Введение
GPS may be dropped and the back screen is cracked/damaged. When prying do not use metal tools as this can cause static damage. The device can be identified by its model number which is located under the small panel on the bottom of the device.
Выберете то, что вам нужно
Locate the round suction cup on the back of the device.
Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
Location of screw is where the suction cup was.
Insert 8mm Hex #T6 screw driver into screw.
Unscrew in counter clockwise direction.
Pry along the edges with the plastic opening tool to separate the back and front panel.
Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard.
Unscrew each of these in a counter clockwise direction.
Remove the Blue Ribbon Cable by pushing each side of the plastic holder with the nylon spudger.
This will remove the LCD screen from the motherboard.
Unplug the wire connecting to the speaker by pinching the sides connected to the back screen.
Pull back away (in the opposite direction) from the connector.
Unplug the battery, the same way we unplugged the speaker by pinching the sides of the connection.
Pull away from the connector
Replace the back cover screen, now that all parts have been properly removed.
