Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
Starting at the corners, carefully pry up the screen bezel.
Remove the four Phillips #00 screws around the edge of the screen.
Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
Remove the frame from the housing.
Lifting from the upper edge of the screen, tilt the screen away from the device.
Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
Two Phillips #00 screws are located at the bottom of the first picture.
The third screw is hidden under the orange ribbon cable, near the screen.
Flip the screen and motherboard over.
Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
Disconnect the speaker cable connector from the motherboard.
Remove the motherboard and screen from the housing.
Slip a small plastic opening tool under the battery and slowly pry the battery up.
Remove the battery from the housing.
13 участников успешно повторили данное руководство.
12 Комментариев
Awesome and very detailed guide. Thanks for this.
Great demo, for replacement tomtom batteries take a look at : TomTom batteries
based in the UK they are reliable and give a truly longer charge
