1. Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
    • Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
  2. Unscrew the two T5 screws using the T5 Torx Screwdriver.
    • Unscrew the two T5 screws using the T5 Torx Screwdriver.
  3. Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
    • Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
  4. Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
    • Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
  5. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Remove the screen from of the face-plate.
    • Remove the screen from of the face-plate.
  7. Insert the new screen into the face-plate.
    • Insert the new screen into the face-plate.
  8. Reattach the yellow ribbon cable to the motherboard.
    • Reattach the yellow ribbon cable to the motherboard.
  9. Using two hands, hold both ends of the device and snap the two plates together.
    • Using two hands, hold both ends of the device and snap the two plates together.
  10. Re-insert the two T5 screws and tighten.
    • Re-insert the two T5 screws and tighten.
  11. Re-apply the label edges back down to cover the screws.
    • Re-apply the label edges back down to cover the screws.
Заключение
2 участников успешно повторили данное руководство.
Mike Sollars
Участник с: 11.07.2013
471 Репутация
Автор 3 руководств
Команда
WRI115, Team 1-1, Ruszkiewicz Spring 2013 Member of WRI115, Team 1-1, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G1
4 членов
Автор 3 руководств
Один комментарий
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 4
За всё время: 1,383
