Tools Best Practices
Выберете то, что вам нужно
  1. Tools Best Practices, Metal Spudger: шаг 1, изображение 1 из 2 Tools Best Practices, Metal Spudger: шаг 1, изображение 2 из 2
    • The metal spudger is a fantastic tool, but it's also a tool of much debate. Here at iFixit, we tend to call on the metal spudger only when we need a member of the brute squad.
    • Use the metal spudger to:
    • Remove extra-stubborn plastic/metal casings, or scrape away tough adhesive.
    • Depress or lift stubborn release tabs.
    • Keep in mind:
    • The metal spudger is not electrostatic discharge (ESD) safe. Irresponsible use may result in electrical shock or permanent injury.
    • Poor use may permanently damage your device.
    • Do not use this tool on exposed or fragile internal components, batteries, or glass screens.
  2. Tools Best Practices, Plastic Opening Tool: шаг 2, изображение 1 из 2 Tools Best Practices, Plastic Opening Tool: шаг 2, изображение 2 из 2
    • The plastic opening tool comes in a few different styles, and is your go-to tool for removing screens and separating cases. It has a very thin non-destructive edge that gets in between small cracks easily.
    • Use the plastic opening tool to:
    • Lift zero insertion force (ZIF) tabs and disconnect cable connectors.
    • Pry open tightly sealed device cases.
    • Remove digitizers and glass screens.
    • Lift, cut, or remove tape, adhesive, and/or thermal paste.
  3. Tools Best Practices, Spudger: шаг 3, изображение 1 из 2 Tools Best Practices, Spudger: шаг 3, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Heavy-Duty Spudger
    • Your friendly neighborhood nylon spudger can do amazing things. With antistatic pointed and blunt tips, it’s a great all-around tool to use on internal components.
    • Use the spudger to:
    • Disconnect cable connectors.
    • Pry components free.
    • Aid in soldering.
    • Remove thermal paste, adhesive, or tape.
    • Be sure to list the appropriate tool in your guide. The heavy duty spudger is a more robust version of the standard spudger. They look similar, but one of these things is not like the other.
  4. Tools Best Practices, Tweezers: шаг 4, изображение 1 из 2 Tools Best Practices, Tweezers: шаг 4, изображение 2 из 2
    • With blunt or curved tip options, the ESD safe tweezers are a tricksy little tool. They're especially helpful if you have thick, hobbitsy, fingers.
    • Use tweezers to:
    • Remove loose screws or small components that are difficult to access.
    • Gently remove ribbon cables.
    • Peel heated panels after applying heat.
    • The angled and fine-tip tweezers have very sharp tips. Exercise caution around delicate ribbon cables and your fingers.
  5. Tools Best Practices, Opening Picks: шаг 5, изображение 1 из 2 Tools Best Practices, Opening Picks: шаг 5, изображение 2 из 2
    • Opening picks are an industry favorite for maintaining a separation between screens and cases, or for breaking up long sections of adhesive. Feel free to explore your options.
    • Use opening picks to:
    • Cut adhesive strips that secure screens.
    • Use as a placeholder to prevent large screens from receding back into the frame.
    • Scrape or remove adhesive or tape.
    • Apply or remove thermal paste.
  6. Tools Best Practices, Magnetic Project Mat: шаг 6, изображение 1 из 2 Tools Best Practices, Magnetic Project Mat: шаг 6, изображение 2 из 2
    • This handy mat can be your best friend during a replacement. Be sure to take advantage of the dry erase surface and keep track of your screws and steps along the way! You won't regret it.
    • The magnetic project mats are covered with a thin layer of plastic to create a dry erase surface. Do not remove this layer or peel the edges up.
Финишная прямая
96 человек успешно провели ремонт по этому руководству.
Richard
Участник с: 02/07/17
34 338 Репутация
Автор 11 руководств
2 Комментарии к руководству
El simpático spudger de nailon de tu vecindario tiene la capacidad de realizar acciones sorprendentes. Con puntas agudas y romas antiestáticas, es una herramienta de gran versatilidad para emplear en elementos internos. speed stars
Tyler Tommy - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 61
За последние 30 дней: 223
За всё время: 12,470
