Введение
Replacing the cutting blade on a lawn mower is important to ensure that your grass is cut correctly and that your lawn mower is running efficiently. This is a simple fix that requires little to no expertise or previous experience. Just make sure to be careful when handling the blade itself and all should run smoothly.
Выберете то, что вам нужно
Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
Place wood in between the blade and the wall of the mower to ensure that the blade does not move while you are tightening or loosening the bolt.
Using the 5/8 wrench, turn the blade counter clockwise until the bolt is loose then pull the blade off.
Using the 5/8 ratchet, turn the bolt clockwise until the bolt does not turn anymore.
This simple fix should help make the lawn mower function efficiently and safely for years to come.
3 участников успешно повторили данное руководство.
