Введение
Follow this guide to replace the drive belt on a 2017 Toro Stump Grinder SGR-13 model 22615HD.
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Tilt the machine so that it is resting on the handle with the cutter wheel raised.
Use a 14 mm socket to remove the fasteners securing the belt guard:
One 10 mm bolt
One 10 mm nut
Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
Use a 1/2 inch wrench to loosen the two bolts behind the centrifugal clutch enough to allow the motor to slide freely. Do not remove the bolts.
Wrap a piece of tape around the upper half of the tensioner bolt to mark the location of the second nut.
Use a 9/16 inch wrench to loosen the nut on the lower half of the tensioner bolt until the motor can slide forward as much as possible.
Lift the drive belt up and away from the machine while rolling it towards the cutter head to gradually roll it off of the pulley.
3 участников успешно повторили данное руководство.
