Введение
This guide shows how to remove and replace the left spindle on the Toro Walk Behind Mower 21199HD 2018.
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
Chock the rear wheels to prevent the mower from rolling during service.
While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
Remove the grass bag.
Use a 3/8-inch socket to remove the four bolts securing the belt guard:
Three 1 inch-long recessed bolts
One 1 1/2 inch-long bolt
Pull the belt guard straight off the front of the mower to remove it.
Loosen, but don't remove, the belt tensioner to give the belt some slack.
Use a flathead screwdriver to pry off the plastic plug cap.
Remove the plug cap.
Use a 3/8 inch socket to remove the four bolts securing the upper belt guide to the pulley.
Lift the belt up and over the left sprocket.
Move the belt to the front of the mower, out of the way of the belt tensioner.
Spin the left sprocket, with the blade attached underneath, until it is in a safe position, then place the belt on the sprocket.
Spin both blades to ensure they don't touch during a 360˚ rotation.
Use an impact wrench with a 3/4 inch socket to remove the left sprocket bolt.
If necessary, use a punch or screwdriver to lock the sprocket in place during removal, lining up the hole in the sprocket with the hole in the blade guard.
While holding the spindle shaft from underneath, lift the sprocket up to remove it.
Grabbing the spindle shaft from the bottom, lower it down through the spindle.
Remove the spindle shaft from underneath the mower.
Tilt the mower onto its side so the spindle assembly is facing out.
Use a 1/2 inch socket to remove the four spindle bolts.
