Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to replace your Toshiba AT1304T keypad
Выберете то, что вам нужно
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
If needed, use the flathead screwdriver to gently pry the panel from the phone.
Using your fingers, lift the panel from the device.
Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
Use a flathead screwdriver to gently pry the logic board and keypad from the device.
